witam mam taki problem ze auto odpala jak postoi 30 min przejade kawalek i potrafi zgasnac podczas jazdy i wtedy znow nie odpala dopiero po odczekanie. Prosze o pomoc auto to audi a6 c7 3.0 diesel w automacie 2012 rok kod silnika to cla
Friday,04,October,2019,04:47:47:34654
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 19.6.2.0 (x64)
Data version: 20190930 DS308.0
www.Ross-Tech.com
VIN: WAUZZZ4G8CN110260 License Plate: KRISSS
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 3B 42 44 46 52 53 5F 62 72
01-Engine -- Status: Malfunction 0110
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
3B-Sensor Elect. -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: Malfunction 0010
5F-Information Electr. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine
Cannot be reached
Address 02: Auto Trans (J217) Labels:| 0AW-927-156.clb
Part No SW: 4G1 927 155 F HW: 0AW 927 156 K
Component: 0AW 30TDI RdW H04 0002
Revision: --H04--- Serial number: 0000001223
Coding: 000001
Shop #: WSC 02311 785 00200
ASAM Dataset: EV_TCMVL381 A02428
ROD: EV_TCMVL381.rod
VCID: 2F672427769A12370E-807A
2 Faults Found:
2264 - No Communication with Engine Control Module (SAE ECM/PCM)
U0100 00 [175] - -
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 4
Mileage: 183006 km
Date: 2019.09.29
Time: 10:59:53
Engine speed: 100.00 /min
Transmission input speed: 1388 /min
Transmission output speed: 690 /min
Engine torque: 200 Nm
Transmission fluid temperature: 47 °C
Accelerator position: 25.2 %
Clutch status: 6
Unlearning counter according OBD: 40
Occurrence_counter_over_length_of_life: 20
7066 - No Communication with Engine Control Module (SAE ECM/PCM)
U0100 00 [047] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Mileage: 183006 km
Date: 2019.09.29
Time: 10:59:53
Transmission input speed: 1387 /min
Transmission output speed: 689 /min
Clutch status: 1
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 H HW: 4G0 907 379 H
Component: ESP PREMIUM H09 0361
Revision: -------- Serial number: --------------
Coding: 07A18701E085E180CB00
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ESPPremiAU57X 004028
ROD: EV_ESPPremiAU57X_004_AU57.rod
VCID: 3669114389C023FF4D-8062
14 Faults Found:
0004 - Brake Switch (F)
P0571 00 [137] - Implausible Signal
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 69
Mileage: 183021 km
Date: 2019.10.04
Time: 12:35:26
VzRef: 00
Bit Info 1: 80
Bit Info 2: 0F
Bit Info 3: 02
Bit Info 4: 1F
F-Path: 01
F-Type: F6
Uz: A0
0069 - Function Restricted due to Missing Message(s)
U1111 00 [137] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 69
Mileage: 183006 km
Date: 2019.09.29
Time: 10:59:53
VzRef: 56
Bit Info 1: 00
Bit Info 2: 40
Bit Info 3: 26
Bit Info 4: 1F
F-Path: 00
F-Type: E3
Uz: BE
0071 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 69
Mileage: 183006 km
Date: 2019.09.29
Time: 10:59:53
VzRef: 56
Bit Info 1: 00
Bit Info 2: 40
Bit Info 3: 26
Bit Info 4: 1F
F-Path: 00
F-Type: F0
Uz: BE
0073 - Function Restricted due to Missing Message(s)
U1111 00 [137] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 69
Mileage: 183006 km
Date: 2019.09.29
Time: 10:59:53
VzRef: 56
Bit Info 1: 00
Bit Info 2: 40
Bit Info 3: 26
Bit Info 4: 1F
F-Path: 00
F-Type: F5
Uz: BE
0075 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 69
Mileage: 183006 km
Date: 2019.09.29
Time: 10:59:53
VzRef: 56
Bit Info 1: 00
Bit Info 2: 40
Bit Info 3: 26
Bit Info 4: 1F
F-Path: 00
F-Type: F8
Uz: BE
0077 - Function Restricted due to Missing Message(s)
U1111 00 [137] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 69
Mileage: 183006 km
Date: 2019.09.29
Time: 10:59:56
VzRef: 53
Bit Info 1: 00
Bit Info 2: 62
Bit Info 3: 26
Bit Info 4: 1F
F-Path: 00
F-Type: FD
Uz: A6
0091 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 69
Mileage: 183006 km
Date: 2019.09.29
Time: 10:59:53
VzRef: 56
Bit Info 1: 00
Bit Info 2: 40
Bit Info 3: 26
Bit Info 4: 1F
F-Path: 01
F-Type: 0C
Uz: BE
0486 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 69
Mileage: 183006 km
Date: 2019.09.29
Time: 10:59:54
VzRef: 55
Bit Info 1: 00
Bit Info 2: 60
Bit Info 3: 26
Bit Info 4: 1F
F-Path: 02
F-Type: 04
Uz: BE
0722 - Function Restriction due to Implausible Message(s)
U1112 00 [129] - -
MIL ON - Not Confirmed - Tested Since Memory Clear
0725 - Function Restriction due to Implausible Message(s)
U1112 00 [129] - -
0838 - Function Restriction due to Faults in Other Modules
U1113 00 [129] - -
0727 - Function Restriction due to Implausible Message(s)
U1112 00 [129] - -
0729 - Function Restriction due to Implausible Message(s)
U1112 00 [129] - -
0731 - Function Restriction due to Implausible Message(s)
U1112 00 [129] - -
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 4H0 907 064 BG HW: 4H0 907 064 BG
Component: BCM2 2.0 H31 0333
Revision: 00002001
Coding: 01B93006000000000000
VCID: 6FE7E427BE1A52374E-803A
Subsystem 2 - Part No SW: 4H0 905 852 C HW: 4H0 905 852 C
Component: J764 ELV MLB H39 0046
Serial number: 2311000282243010
1 Fault Found:
01330 - Central Control Module for Central Convenience (J393)
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 6
Fault Frequency: 4
Reset counter: 69
Mileage: 183006 km
Time Indication: 0
Date: 2019.09.29
Time: 10:59:54
Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-2Z.clb
Part No SW: 4G0 820 043 G HW: 4G0 820 043 G
Component: KLIMA 2 ZONEN H10 0063
Serial number: 28121100040842
Coding: 3622000820
ASAM Dataset: EV_AirCondiBasisUDS 002039
ROD: EV_AirCondiBasisUDS_002.rod
VCID: 234FD8172A52A6579A-8076
1 Fault Found:
0331 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 6
Reset counter: 69
Mileage: 183006 km
Date: 2019.09.29
Time: 10:59:54
Voltage terminal 30: 14.77 V
Outside air temperature: 18.0 °C
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 4H0 907 063 BH HW: 4H0 907 063 A
Component: BCM1 2.0 H12 0111
Revision: 12012002 Serial number: 00000001345727
Coding: 690000108034A7E00105008000005F5F0F9DC60827080101000004402000
Subsystem 1 - Part No SW: 4G2 955 119 HW: 4G8 955 119 A Labels: 1KX-955-119.CLB
Component: WWS57X 111123 H35 0051
Serial number: 111206052023
Coding: 0045F7
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 11837793
Coding: 02512B
Subsystem 3 - Part No SW: 4G0 941 531 HW: 4G0 941 531
Component: E1 - LDS H07 0044
Serial number: 12 12 2011 00000469
Subsystem 4 - Part No SW: 4G0 907 658 A HW: 4G0 907 658 A
Component: Humidity_Sens H02 0002
Serial number: 1528C5E5000000000001
2 Faults Found:
00979 - Lamp for Low Beam; Right (M31)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 67
Mileage: 182999 km
Time Indication: 0
Date: 2019.09.22
Time: 08:23:00
01314 - Engine Control Module
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 6
Fault Frequency: 3
Reset counter: 69
Mileage: 183006 km
Time Indication: 0
Date: 2019.09.29
Time: 10:59:00
Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 L HW: 4H0 919 475 C
Component: PARKHILFE ACC H07 0043
Revision: 11001001 Serial number: 55901134801845
Coding: 080307
ASAM Dataset: EV_EPHVA18AU57X0000 002005
ROD: EV_EPHVA18AU57X0000_002_AU57.rod
VCID: 3B7F0077B2E2FE97B2-806E
1 Fault Found:
12648448 - Databus
U1121 00 [009] - Missing Message
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 69
Mileage: 183006 km
Date: 2019.09.29
Time: 10:59:53
Address 15: Airbags (J234) Labels:* 4H0-959-655.clb
Part No SW: 4H0 959 655 C HW: 4H0 959 655 C
Component: Airbag10.43 H40 0040
Revision: -------- Serial number: 003JG0062HJ$
Coding: 30323436313330303537554A305234473053
ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
ROD: EV_AirbaAU10BPAAU64X_VW51.rod
Crash sensor for side airbag: driver side:
Serial number: 3575HRB405H11FPID95G
Crash sensor for side airbag: front passenger side:
Serial number: 3585HRB405J11FPI4G4G
Crash sensor for side airbag: rear: driver side:
Serial number: 3515JRB405T0TGJKLOCZ
Crash sensor for side airbag: rear: passenger side:
Serial number: 3525JRB404R1082K59K0
Crash sensor for front airbag: driver side:
Serial number: 3554VRB40610TO4OF1G
Crash sensor for front airbag: front passenger side:
Serial number: 3564VRB40610TO4O90T2
No fault code found.
Address 16: Steering wheel (J527) Labels:. 4H0-953-568.clb
Part No SW: 4G0 953 568 A HW: 4G0 953 568 A
Component: Lenks.Modul H05 0201
Revision: 00000000 Serial number: 20120103000109
Coding: 000035
VCID: 3065275B63A40DCF17-8064
Subsystem 1 - Part No SW: 4G0 951 528 E HW: 4G0 951 528 E
Component: E221 - MFL H09 0009
Address 17: Instruments (J285) Labels:. 4H0-920-xxx-17.clb
Part No SW: 4G8 920 950 K HW: 4G8 920 950 K
Component: MDieGb H34 0209
Revision: 26450207 Serial number: 658091211592007
Coding: 33A6100003012600010000
ASAM Dataset: EV_RBC7KMID 004045
ROD: N/A
VCID: 37771C478ECADAF756-8062
Unsupported vehicle.Please upgrade to a current Ross-Tech interface.
No ASAM data for: "EV_RBC7KMID" (AU57)
1 Fault Found:
16776971 - ROD - Unknown Error Code
- 00 [009]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 69
Mileage: 183006 km
Date: 2019.09.29
Time: 10:59:53
Address 19: CAN Gateway (J533) Labels:* None
Part No SW: 4G0 907 468 F HW: 4G0 907 468
Component: J533--Gateway H08 0214
Revision: -------- Serial number: 00000000343813
Coding: 00CD077D00
ASAM Dataset: EV_GatewUDS 001025
ROD: EV_GatewUDS_AU57.rod
VCID: 336F28579AB236D76A-8066
Battery Monitoring Control Module:
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0141
Serial number: 00000000003790408314
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
Component: J532_DCDCStab H17 0042
Serial number: 12004001169011200181
1 Fault Found:
4224 - No Communication with Engine Control Module (SAE ECM/PCM)
U0100 00 [009] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 8
Reset counter: 69
Mileage: 183006 km
Date: 2019.09.29
Time: 10:59:54
Voltage terminal 30: 14.9 V
Voltage terminal 15: 14.9 V
Control Module temperature: 23 °C
System status: Terminal 15 on
IN ESP_standstill flag: no standstill detected
Engine running: On
IN ZAS_Te_X: On
Terminal 15 status via CAN: On
Terminal 15 status: On
Datenfeld: 0
Address 3B: Sensor Elect. (J849) Labels: 4G0-907-637.clb
Part No SW: 4G0 907 637 HW: 4G0 907 637
Component: SARA 3D H02 0004
Revision: -------- Serial number: EJ1BPA32013P3V0
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_SARA 006014
ROD: EV_SARA_006.rod
VCID: 6BDFF0378202AE1762-803E
Address 42: Door Elect, Driver (J386) Labels:. 4H0-959-793.clb
Part No SW: 4G8 959 793 E HW: 4G8 959 793 A
Component: TSG FA H05 0212
Coding: 011C16204001620002080002
Shop #: WSC 02312 785 00200
VCID: 42817D93DD088F5FF1-8016
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 69
Mileage: 183006 km
Time Indication: 0
Date: 2019.09.29
Time: 10:59:58
Address 44: Steering Assist (J500) Labels:| 4G0-909-144.clb
Part No SW: 4G0 909 144 L HW: 4G0 909 144 G
Component: RCEPS H35 0010
Revision: 00001000 Serial number: 0013268974
Coding: 101000010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
VCID: 32612D5365A83FDF61-8066
1 Fault Found:
3158274 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 9
Reset counter: 69
Mileage: 183006 km
Date: 2019.09.29
Time: 10:59:54
Write only channel
Address 46: Central Conv. (J393) Labels:. 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0166745620
Coding: 013B062220B9040083200904000104000000000000000000000000000000
Subsystem 1 - Part No: 4G0 951 177
Component: DWA-Sensor H01 0010
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 69
Mileage: 183006 km
Time Indication: 0
Date: 2019.09.29
Time: 10:59:54
00230 - Transmission Park Selector Switch (F305)
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 69
Mileage: 183021 km
Time Indication: 0
Date: 2019.10.04
Time: 12:37:01
Address 52: Door Elect, Pass. (J387) Labels:. 4H0-959-792.clb
Part No SW: 4G8 959 792 E HW: 4G8 959 792 A
Component: TSG BF H05 0212
VCID: 4183729FD80E9447E8-8014
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 69
Mileage: 183006 km
Time Indication: 0
Date: 2019.09.29
Time: 10:59:58
Address 53: Parking Brake (----) Labels: 4H0-907-801.clb
Part No SW: 4H0 907 801 E HW: 4H0 907 801 A
Component: EPB-4 H03 0012
Revision: -------- Serial number: 00000000075070
ASAM Dataset: EV_ParkiBrake 001022
ROD: EV_ParkiBrake_VW51.rod
VCID: 2A5135334D78771FD9-807E
5 Faults Found:
333568 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 69
Mileage: 183006 km
Date: 2019.09.29
Time: 10:59:53
Voltage terminal 30: 14.8 V
Internal Fault ID: 49
Vehicle speed: 86 km/h
Network management state: normal
Function light in parking brake button: OFF
Red operating lamp: OFF
Red warning lamp: OFF
Green operating lamp: OFF
Yellow warning lamp: OFF
RWU: not active
DSD: not active
HTR: not active
ECD: not active
ACC requested apply: not active
Auto Adjust: not active
General Inspection Function: not active
Internal Parking Brake state: Dynamic
Status of parking brake button: Not operated
Status ParkingBrake left: Open
Status ParkingBrake right: Open
334080 - Function Restricted due to Missing Message(s)
U1111 00 [137] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 69
Mileage: 183006 km
Date: 2019.09.29
Time: 10:59:53
Internal Fault ID: 51
RWU: not active
DSD: not active
HTR: not active
ECD: not active
331264 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 69
Mileage: 183006 km
Date: 2019.09.29
Time: 10:59:53
Internal Fault ID: 99
RWU: not active
DSD: not active
HTR: not active
ECD: not active
331520 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 69
Mileage: 183006 km
Date: 2019.09.29
Time: 10:59:53
Internal Fault ID: 100
RWU: not active
DSD: not active
HTR: not active
ECD: not active
331776 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 69
Mileage: 183006 km
Date: 2019.09.29
Time: 10:59:52
Internal Fault ID: 101
RWU: not active
DSD: not active
HTR: not active
ECD: not active
Address 5F: Information Electr. (J794) Labels: Redir Fail!
Part No SW: 4G0 035 193 D HW: 4G0 035 193 D
Component: RMC Cnct Nav H52 0761
Coding: 0101010001415B47002B060301010000010000
VCID: 244DDB0B275CA16FE3-8070
Subsystem 1 - Part No: 8X0 919 884 D
Component: P13-50-11.06 0002
Subsystem 2 - Part No SW: 4G0 919 603 HW: 4G0 919 603
Component: DU6 Basic H42 0084
Serial number: 9464L.0B2501818
Subsystem 3 - Part No SW: 4G2 919 610 B HW: 4G2 919 610 B
Component: E380 BDT C7 H11 0204
Serial number: 90349KLJ000HD
Address 62: Door, Rear Left (J388) Labels:. 4H0-959-795.clb
Part No SW: 4G8 959 795 E HW: 4G8 959 795 A
Component: TSG HL H04 0212
Coding: 010814204001620002080002
VCID: 448D7B8BC71C816FC3-8010
Address 72: Door, Rear Right (J389) Labels:. 4H0-959-795.clb
Component: TSG HR H04 0212
End-------------------------(Elapsed Time: 04:13)--------------------------
Address 46: DTCs cleared
Address 19: DTCs cleared
Address 53: DTCs cleared
stabilization program fault
lukasz
