[A6C6] Lampy przednie(przepalone ledy)
Thanks!carlos666 pisze:Off course.
Please ask.
I'll try to summarize the essence of the problem.
My problem with the connection of new headlights with DRL. Needed module "09" with the index 279 and the necessary software from the "K" on my car there! I used a scheme which is here in this thread on the pilgrim 4.
Today tried to connect to this scheme + encoding you want in the module "09" (0005122). But yet, without success, DRL did not working.I deadlocked and now I do not know whether all functional DRL headlights on, or is it I'm not doing?
Earlier, I used one piece of advice to pet and fondle another forum where it was adapted set as pins on the headlights themselves.
I moved the pins on the headlights, and then used the scheme with this forum.Maybe in this problem that DRL is not working?
Here's a quote to adaptation the pins on the headlights:
"According to my car (June 2005) and the new A6 FL headlight (4F0 941 003 CP) that I have bought, there is small PIN adaptation to do :
- the side light PIN ( number eight) of the new headlight has to be moved to PIN 10 (in replacement of one of the two Leds wires),
- on the new headlight, Leds have two wires. Both has to be pinned together on PIN 12, to have direct +12V,
- the rest, I think, is OK."
Thanks in advance!
Regards!
Daniel
P.S.
Ask if something and I'll add.
[ Dodano: 2010-10-23, 23:16 ]
Here is the error log in the blocks after the change of PIN and encryption module "09":
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 1010
0E-Media Player 1 -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: Cannot be reached 1100
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 08: Auto HVAC Labels: 4F0-910-043.lbl
Part No SW: 4F0 910 043 HW: 4F1 820 043 AA
Component: KLIMABETAETIGUNGH20 0170
Revision: 00000031 Serial number: 00000000332034
Coding: 0524292
Shop #: WSC 02325 785 00200
1 Fault Found:
00739 - Coolant Circulation Pump (V50)
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 3
Fault Frequency: 10
Reset counter: 7
Mileage: 154465 km
Time Indication: 0
Date: 2010.10.07
Time: 13:57:30
Freeze Frame:
Temperature: 21.0°C
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 K HW: 4F0 907 279
Component: ILM Fahrer H17 0240
Revision: 00000000 Serial number: 4F0907279
Coding: 0005122
Shop #: WSC 02335 785 00200
Part No: 4F1 910 113 C
Component: Wischer AudiC6 H05 0210
Coding: 00064784
Shop #: WSC 02335
Part No: 4E0 910 557 A
Component: REGENLICHTSENSORH13 0090
Coding: 00146221
Shop #: WSC 02335
2 Faults Found:
02745 - Bulb for Daytime Running Light; Left
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 243
Mileage: 154748 km
Time Indication: 0
Date: 2010.10.23
Time: 17:19:00
02746 - Bulb for Daytime Running Light; Right
011 - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 243
Mileage: 154748 km
Time Indication: 0
Date: 2010.10.23
Time: 17:19:00
Address 19: CAN Gateway Labels: 4F0-910-468.lbl
Part No SW: 4F0 910 468 A HW: 4F0 907 468 D
Component: Gateway H11 0070
Revision: 11 Serial number: 1300806B258441
Coding: 6DFE73C41B0104
Shop #: WSC 80093 222 69422
3 Faults Found:
01771 - Control Module for Headlight Range (J431)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 223
Mileage: 154478 km
Time Indication: 0
Date: 2010.10.11
Time: 09:36:58
01044 - Control Module Incorrectly Coded
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 7
Mileage: 154478 km
Time Indication: 0
Date: 2010.10.11
Time: 09:38:18
00457 - Control Module for Network (J519)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 2
Reset counter: 24
Mileage: 154478 km
Time Indication: 0
Date: 2010.10.12
Time: 11:45:27
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
Component: TSG FA H12 0120
Revision: 00000000 Serial number: ’G$
Coding: 0002570
Shop #: WSC 02327 785 00200
3 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 3
Reset counter: 25
Mileage: 154478 km
Time Indication: 0
Date: 2010.10.08
Time: 11:58:37
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 4
Fault Frequency: 3
Reset counter: 25
Mileage: 154478 km
Time Indication: 0
Date: 2010.10.08
Time: 11:58:37
02111 - Motor for Window Regulator
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Freeze Frame:
Fault Status: 00100101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 9
Mileage: 154478 km
Time Indication: 0
Date: 2010.10.12
Time: 15:12:48
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
Component: TSG BF H12 0120
Revision: 00000000 Serial number: dY#
Coding: 0002570
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 3
Reset counter: 25
Mileage: 154478 km
Time Indication: 0
Date: 2010.10.08
Time: 11:58:38
Freeze Frame:
Fault Priority: 4
Fault Frequency: 3
Reset counter: 25
Mileage: 154478 km
Time Indication: 0
Date: 2010.10.08
Time: 11:58:38
Address 55: Xenon Range
Cannot be reached
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: J0644 BEM H12 0590
Revision: 00000000 Serial number: 00000000156583
Shop #: WSC 40090 222 21250
Part No: 4F0 915 105 B
Component: von MLA 0611210639
Coding: 34463039313531303542204D4C4130363131323130363339
Shop #: WSC 00000 384 00290
5 Faults Found:
02272 - Quiescent Current Stage 1
Freeze Frame:
Fault Priority: 7
Fault Frequency: 43
Mileage: 153821 km
Time Indication: 0
Date: 2010.09.13
Time: 21:25:49
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 13
Mileage: 154478 km
Time Indication: 0
Date: 2010.10.08
Time: 14:20:27
02276 - Quiescent Current Stage 5
Freeze Frame:
Fault Priority: 7
Fault Frequency: 7
Mileage: 154478 km
Time Indication: 0
Date: 2010.10.08
Time: 14:20:37
02274 - Quiescent Current Stage 3
Freeze Frame:
Fault Priority: 7
Fault Frequency: 6
Mileage: 154478 km
Time Indication: 0
Date: 2010.10.08
Time: 14:20:47
02277 - Quiescent Current Stage 6
Freeze Frame:
Fault Priority: 7
Fault Frequency: 5
Mileage: 154478 km
Time Indication: 0
Date: 2010.10.08
Time: 14:20:57
- Imię: Karol
- Rocznik: 2016
- Silnik: 4.2 360KM
First!
Connect cable in lamp by original.
Next change cable in 09 module step by step instruction from this post.
Your coding is OK, but for make sure change to 0005121 or 0005021 or 0005321.
Have you tried to power the LED in lamp directly from the battery?
And very important.You must fixed this problem:
Cannot be reached - Its no good...
carlos666 pisze:First!
Thanks carlos!
By items:
1) Now it will be difficult to create one, as the lights are now installed on my car.
2) Set as yesterday pinout of the module "09" is exactly as stated here on forum.I have only left open question of two extra cables from the adapter, which according to the scheme of this cable must connect to pin 6 and 1.
Yesterday, I turn them off of the pin as it is nor how to work LED!
What do you think about this? Should they join or not and where?
3) I tried different encoding after connecting! Now on the car I left the pinout for the encoding scheme 0005122.No can now try it and other encodings.
Carlos, there is a module of "09" is more a function of adaptation to channel.Maybe there need to change to another channel?
4) No, because I don `t know how exactly it makes no if you know what and how on what the pin must be connected, we can try this set.
5) How? There are ideas like this create one? What would I fix it?
Thank you for your help!
nie jestem zdecydowany na jakie lampy zmienić
- RS6 fajnie wyglądają w dzień ,ale nie wiem jak z włączonymi LEDami [ i czy z daleka to 10 ledów się nie zlewa zbytnio - wizualnie ], i ponoć częściej się przepalają
- Lift Fajowo wyglądają jak mają włączone LEDY , rzadziej się przepalają niż RSy
Ma ktoś fotki lub linki porównujące jak świecą Ledy w Rs i Lifcie
czy to prawda ,że przepalają się w momencie odpalania auta i wstawiają opornik aby się tego ustrzec
i co doradzacie RSy czy Lift
Cannot be reached - Its no good...[/quote]
Carlos, yesterday I tried to enter "55" block with VAGCOM but no results.
If you attempt to enter the block writes_"Cannot response from controler"
What does this mean and why?This is my xenon/Bi-xenon ballast.
- pama
- Imię: Forum Tomasz
- Rocznik: 2007
- Silnik: 3.0 ASN 220KM
co do opornika.. to nie ma on na celu ochrone przed przepalaniem.. a realizowac funkcje sciemniania:)))Salah Ad-Din pisze: czy to prawda ,że przepalają się w momencie odpalania auta i wstawiają opornik aby się tego ustrzec
gdyz co LEDow dochodzi 12V z postoju i dziennych..
zeby sie LEDy sciamnialy przy wlaczonych mijania.. musza przygasnac.. stad spadek napiecia realizowany przez opornik.
ja sam sie zastanawiam nad wymiana calej lampy na model po FL..,
listwa od RS fajnie wyglada.. ale trzeba kombinowac ze zderzakiem i halogenami..
<smuty>
