Zrobilem scan auta , jaki moze byc powod ze autem telepie
wczoraj wracajac z pracy mialem wiele szczescia ostatnie kilometry zaczelo telepac autem na wolnych , filtr DPF na wyswietlaczu pokazywalo ze od razu zapchany ? autem nieda sie jechac , nie odpalam go . Postawilem na parking zrobilem scan , szukam mechanika warsztat ,
wstawie moj test auta co myslicie co moze byc ...
Wednesday,03,June,2015,17:12:45:65217
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
VIN: WAUZZZ4F96N007439 License Plate:
Mileage: 266650km-165688mi Repair Order: scan
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 37 42 46 47 4F 52 53 55
56 57 61 62 69 72 76 77
VIN: WAUZZZ4F96N007439 Mileage: 266650km/165688miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: Malfunction 0010
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
57-TV Tuner -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: Redir Fail!
Part No SW: 4F0 910 401 N HW: 4F0 907 401 B
Component: 3.0L V6TDI G001AG 0010
Revision: --H01--- Serial number:
Coding: 0011372
Shop #: WSC 02334 785 00200
VCID: 2757E3DC9613D526F59-8072
2 Faults Found:
008598 - Oxygen (Lambda) Sensor B1 S1
P2196 - 002 - Signal too High (Rich)
Freeze Frame:
Fault Status: 01110010
Fault Priority: 0
Fault Frequency: 70
Reset counter: 255
Mileage: 252776 km
Time Indication: 0
Date: 2014.06.24
Time: 05:42:31
Freeze Frame:
RPM: 2352 /min
Torque: 0.0 Nm
Speed: 134.4 km/h
Duty Cycle: 1.0 %
Duty Cycle: 199.2 %
(no units): 1.0
(no units): 16.0
009236 - Oxygen (Lambda) Sensor B1 S1 Voltage too Low / Air Leakage / Sample Error
P2414 - 001 - - Intermittent
Freeze Frame:
Fault Status: 00110001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 265721 km
Time Indication: 0
Date: 2015.05.12
Time: 17:24:24
Freeze Frame:
RPM: 756 /min
Torque: 109.2 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Duty Cycle: 134.5 %
(no units): 1.0
(no units): 128.0
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4F1 910 156 B HW: 09L 927 156 A
Component: AG6 09L 3,0 TDI RdW 0050
Revision: --H01--- Serial number: 4025202
Coding: 0000001
Shop #: WSC 00000 000 00000
VCID: 234FF7CCE22B3906A91-8076
No fault code found.
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 L HW: 4F0 614 517 L
Component: ESP 8.0 quattro H03 0090
Revision: 00000000 Serial number: 00000000000000
Coding: 0004492
Shop #: WSC 02327 785 00200
VCID: 2D5B11F4B4EFFF760F5-8078
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H30 0220
Revision: 31050601 Serial number: 10600300135298
Coding: 0000135
Shop #: WSC 00477 219 17568
VCID: E3CF37CC22ABF906691-80B6
Subsystem 1 - Part No: 4F0 910 131 G
Component: FBSAUDIC6 EZS H43 0070
Subsystem 2 - Part No: 4F0 910 335
Component: FBSAUDIC6 KSG H26 0080
1 Fault Found:
00193 - Rear Right Door Handle Touch Sensor (G418)
007 - Short to Ground
Freeze Frame:
Fault Status: 01110111
Fault Priority: 3
Fault Frequency: 1
Reset counter: 102
Mileage: 266345 km
Time Indication: 0
Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
Part No SW: 4F1 910 732 E HW: 4E0 035 729 A
Component: Interfacebox H43 5570
Revision: 00000000 Serial number: 393CN057501339
Coding: 0001001
Shop #: WSC 02335 785 00200
VCID: 2649EED89119CC2ECEF-8073
Subsystem 1 - Part No: 4F0 910 609 B
Component: Bedienteil MMIC6H07 0010
Subsystem 2 - Serial number: 00000000126542
Subsystem 3 - Serial number: 0117.03.050000000100010444ÿ
Subsystem 4 - Serial number: 010444ÿ
Address 08: Auto HVAC Labels: 4F0-910-043.lbl
Part No SW: 4F0 910 043 HW: 4F1 820 043 F
Component: KLIMABETAETIGUNGH04 0150
Revision: 00000025 Serial number: 00000000126045
Coding: 0000278
VCID: DBBF0F2C1ADBC1C6211-808E
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 HW: 4F0 907 279
Component: ILM Fahrer H14 0080
Revision: 00000000 Serial number: 4F0907279
Coding: 0013121
VCID: E6C92ED8D1998C2E8EF-80B3
Subsystem 1 - Part No: 4F1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H05 0150
Coding: 00062736
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH10 0050
Coding: 00141886
Shop #: WSC 02335
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBE7133362
VCID: 1C3DCC30DF5506FE68B-8049
Address 15: Airbags Labels: 4F0-910-655-8R.lbl
Part No SW: 4F0 910 655 C HW: 4F0 959 655 B
Component: 32 AIRBAG AUDI8RH29 0230
Revision: 06H29000 Serial number: 0037LD065NLD
Coding: 0013106
Subsystem 1 - Serial number: 6332CSME093A635DA
Subsystem 2 - Serial number: 6342CSME093A4F7CM
Subsystem 3 - Serial number: 6351HSME066C513BB
Subsystem 4 - Serial number: 6361HSME0676675CH
Subsystem 5 - Serial number: 6371VSME06571F15N
Subsystem 6 - Serial number: 6381VSME064F455CZ
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H07 0230
Revision: 00H07000 Serial number: 90026050670008
Coding: 0002142
Shop #: WSC 02323 785 00200
Subsystem 1 - Part No: XXXXXXXXXXX
Component: Lenkradmodul H06 0080
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 930 A HW: 4F0 920 931 F
Component: KOMBIINSTR. M73 H15 0630
Revision: 00700000 Serial number: 4PV302J35
Coding: 2113143
Shop #: WSC 00999 444 64523
VCID: 2143FDC4F8372B16BBD-8074
Address 19: CAN Gateway Labels: 4F0-910-468.lbl
Part No SW: 4F0 910 468 A HW: 4F0 907 468 D
Component: Gateway H10 0060
Revision: 10 Serial number: 120080530702B0
Coding: EDFE73C41B3504
Shop #: WSC 02325 785 00200
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 P HW: 4E0 919 887 D
Component: MNS ECE H51 1060
Revision: 00000000 Serial number: 364JS067602714
Shop #: WSC 00197 204 93976
VCID: 3B7F2FAC7A9B61C6811-806E
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 B HW: 4F0 959 793 B
Component: TSG FA H11 0040
Revision: 00-00000
Coding: 0018026
VCID: 2953E5E48007E356E3D-807C
1 Fault Found:
02115 - Locking Unit for Central Locking
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 32
Reset counter: 157
Mileage: 266345 km
Time Indication: 0
Date: 2015.05.25
Time: 15:52:20
Address 46: Central Conv. Labels: 4F0-910-289.lbl
Part No SW: 4F0 910 289 G HW: 4F0 907 289 G
Component: Komfortgeraet H18 0120
Revision: 01200018 Serial number: 01003376160000
Coding: 0140017
VCID: 2E5916F8B9E9846E36F-807B
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H02 1301
Subsystem 2 - Part No: 4F0 910 177
Component: Innenraumueberw.H01 0020
1 Fault Found:
01503 - Bulb for 3rd Brake Light (M25)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 254
Reset counter: 117
Mileage: 263262 km
Time Indication: 0
Date: 2015.03.03
Time: 16:02:40
Address 47: Sound System Labels: 4F0-910-223-AS.lbl
Part No SW: 4F0 910 223 G HW: 4F0 035 223
Component: Amp.-ASK H09 0350
Revision: 30S00001 Serial number: 02012070409591
Coding: 0000102
Shop #: WSC 00477 219 55591
VCID: 2241F2C8FD31300EA27-8077
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 A
Component: ILM Beifahrer H09 0050
Revision: Serial number: 00000000075628
Coding: 0001103
VCID: DEB9063809C9D4EE46F-808B
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 B HW: 4F0 959 792 B
Component: TSG BF H11 0040
Revision: 00-00000
Coding: 0018026
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 HW: 4F0 907 801
Component: EPB C63C0030 H03 0030
Revision: C63C0030
Coding: 0000321
VCID: DDBB013404CFCFF65F5-8088
Address 55: Xenon Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 C HW: 4F0 907 357 C
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000016
Shop #: WSC 00477 219 51368
Subsystem 1 - Part No: 4F0 941 329 B
Component: AFS-Modul links H01 0010
Subsystem 2 - Part No: 4F0 941 329 B
Component: AFS-Modul rechtsH05 0010
1 Fault Found:
02626 - Dynamic Cornering Light Motor; Right (V319)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00111010
Fault Priority: 2
Fault Frequency: 41
Reset counter: 40
Mileage: 266344 km
Time Indication: 0
Date: 2015.05.25
Time: 15:54:11
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4F0 035 541 B
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 384K 067624933
Coding: 0000001
VCID: 31630D84A8D79B962BD-8064
Address 57: TV Tuner Labels: 4E0-910-146.clb
Part No SW: 4E0 910 146 H HW: 4E0 919 146 E
Component: TV analog TUNER H16 0310
Revision: 00000028 Serial number: 00000000011578
Coding: 0000001
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: ENERGIEMANAGER H12 0490
Revision: 00000000 Serial number: 00000000003188
Shop #: WSC 00477 219 76451
Subsystem 1 - Part No: 4F0 915 105 D
Component: von VA0 3809270189
Coding: 344630393135313035442056413033383039323730313839
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 HW: 4F0 959 795
Component: TSG HL H11 0030
Coding: 0017450
VCID: E9D325E4C087A356A3D-80BC
Address 69: Trailer Labels: 4F0-910-383.lbl
Part No SW: 4F0 910 383 HW: 4F0 907 383
Component: ANHAENGERELEKTR H02 0020
Coding: 0000331
VCID: E2C132C83DB1F00E627-80B7
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 HW: 4F0 959 794
Component: TSG HR H11 0030
Coding: 0017450
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 HW: 4F0 919 283
Component: Parkhilfe 4-Kan H09 0030
Revision: --.--.-- Serial number: 11720505603960
Coding: 0011116
Shop #: WSC 131071 1023 2097151
VCID: E1C33DC438B7EB167BD-80B4
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4E0 910 336 M HW: 4E0 862 335
Component: Handyvorb2 H10 1130
Revision: 00000000 Serial number: 00000007543899
Coding: 0010900
VCID: 2C5D1CF08FF5F67E18B-8079
End ---------------------------------------------------------------------
Address 61: Battery Regul. (4F0 910 181 E)
17:15:04 Group 001: Basic Functions
12.00 V Generator Voltage (specified)
11.90 V Battery Voltage (actual)
0.0 % Dynamic-Field Signal
3.00 s Load Response Time
17:15:04 Group 002: Battery Temperatures && Shut-Off Stages
57.0°C Rail Temperature (actual)
32.5°C Battery Temp. (valuation)
ConsSwOff 0 Emergency Shut-Off
StatCurStg 0 Static-Current Shut-Off Stage
17:15:04 Group 003: Battery Status I
100.0 % Battery Condition
4 ohms Internal Battery Resistance
0 Ah Qv (Battery Aging)
54 Ah Charge
